96 XJ6 Dies randomly
Old 04-23-2015, 06:48 AM
julien4020's Avatar
Waouw, that is amazing !
To my understanding, can the relay send only partial information to the ECU?
I have an issue with my car, with a missfire on cylinder N°2 and I supect the ECU. But could the relay be at fault ?
By the way, very good job !
Julien
Old 04-26-2015, 12:52 AM
rsperle's Avatar
I would swap it out with the AC relay as I did and see if it corrects the issue. Also check out the coils, possibly swap it our for another one, such as #1 and see if the ECU gives a code for that cylinder.
Let us know and good luck!
Ray
Old 04-28-2015, 03:02 AM
julien4020's Avatar
Dear ray,
Thanks for the answer. I have swappped both coils and the spark is still weak and appears randomly. I suspect a bad connection...
I will investigate that and keep you updated !
Julien
Old 04-29-2015, 01:39 AM
rsperle's Avatar
Is the ECM throwing any codes?
Old 04-29-2015, 02:09 AM
julien4020's Avatar
I don't know, Il do not have a code reader... And my garage told me the car was too old
What kind of code reader do you use ?
Tanks for the Help !
Old 04-30-2015, 01:52 AM
rsperle's Avatar
Here is a pic of the scanner I use. It was about 140, and allows me to read real time data in addition to reading and deleting codes. Its an Actron CP9574. Bought it at Sears.
What year is your car? 96 and above are OBD II where as 95 and below is OBD I think.
I would suggest you check into another garage, they don't seem too helpful.
Old 04-30-2015, 02:11 AM
julien4020's Avatar
Tanks for the Help ! I will get one of these device, it might beaucoup helpfull...
Définitively, the garage I went is not a good one !
But I would like to fix the car by myself !
Tomorrow is a Day of, I will work on the car and keep you updated
Julien
  #28
Old 05-02-2015, 12:49 PM
julien4020's Avatar
Hi all !
I have ordered the same OBD tool. Lets see.
I will open a proper thread with a complete description of symptoms and what I did on the car. It id not polite to hijack someone's thread ...
Best regards
julien
Old 05-03-2015, 09:20 PM
rsperle's Avatar
Make sure the scanner is able to read your vehicles computer before you open it. I'm not sure mine can read OBD, but my car is OBDII and that is what I know my scanner can read.
  #30
Old 05-05-2015, 02:53 AM
julien4020's Avatar
Yes I have checked the iso code that seems to beaucoup the right one !
I will receive the scan by the end of the week hopefully !
  #31
Old 05-05-2015, 06:52 PM
Wolfman01869's Avatar
Hey! I have an extra one of these relays that you are welcome to have if you want it. If so, shoot me your address in a message & I'll get it out in the mail to you. It's just collecting dust. FREEBIE!
julien4020 (05-06-2015)
  #32
Old 05-05-2015, 06:54 PM
I bought a Bullydog that does a great job scanning my 96 XJ6 Picked it up at a pawn shop for $20.00.
  #33
Old 05-06-2015, 10:35 AM
julien4020's Avatar
Dear Wolfman01869,
Thanks a lot for the free relay !! Unfortunately, I am located in France so shipping might cost a lot !
I have swapped the relay with the aircon one and it did not change anything. I don't think it is a relay issue and most probably a sensor one
The diagnostic tool will help me, hopefully. I got one from ebay and will receive it next week hopefuly !
I will keep you updated !
Best regards
Julien
  #34
Old 05-07-2015, 05:29 PM
EZDriver's Avatar
Originally Posted by GatorJoe
If you're facing the passenger fender then it's the closest of the 3 to you. They are lined up parallel to the front of the car. Good luck.
GatorJoe, would you by chance know the part number of those relays. I have been having minor stalling for a long time and I think we may have hit on the problem. what I want to do is just replace all three with news. That heat environment is not a good spot and the stall is always after at least a 30 mile drive. Sounds like a heat problem. If you know the part no. it would be appreciated.
  #35
Old 05-07-2015, 07:21 PM
GatorJoe's Avatar
EZDriver, the part number is LNA6706AA. It's a waterproof relay.
EZDriver (05-13-2015)
  #36
Old 05-08-2015, 08:08 PM
Bucky83's Avatar
I'm sure someone who really knows will verify, but I think '95 was the change year. ( some OBDI some OBDII) My '95 is OBDII.
  #37
Old 05-16-2015, 05:48 AM
EZDriver's Avatar
GatorJoe, can you give me a few tips as to how to remove the darn relays. I hesitate to just start jerking on them considering how old the wiring is. It appears they are really locked in place.
  #38
Old 05-16-2015, 12:39 PM
GatorJoe's Avatar
You just have to manhandle them as I recall. You are right in that they are kind of locked in. No tricks, just work them out.
ccfulton
09-20-2015 05:15 PM
Chadly
09-15-2015 10:18 AM
Boeingtravel95
09-14-2015 05:01 PM
hen555
09-07-2015 11:13 PM
Quick Reply: 96 XJ6 Dies randomly
