96 XJ6 head gasket
Old 05-29-2011 | 06:41 PM
darkmon316's Avatar
Originally Posted by panchostatus
I know, it was within factory tolerance of being machined down; if I remember right my man only shaved down half of the allowable limit.
so I could do it again if I had to!
& also the clearance for each valve only changed maybe .01mm after it was all said & done. so as far as I know, I'm good, everything else is still straight and in good order.
Hello,
My name is Kevin. I have a 1995 Jaguar Vanden Plas with 176,000 miles on it. I was reading in your post where you changed some valves on your 1996 XJ6 cylinder head. Did you replace the valves yourself, and is it very hard to do? I ask this question because I have some bent valves on my cylinder head from the primary timing chain breaking while I was on the interstate driving at 60 MPH and I need to change out some valves because I have three cylinders with no compression. I have taken the cylinder head off and I can tell that the valves are bent and are staying open on the compression stroke.
Kevin
1995 Jaguar Vanden Plas/ AJ16 /4.0L engine /176,000 miles/6 cylinder
aholbro1
08-05-2021 06:02 AM
vicom
09-17-2015 04:32 AM
1964Daimler
09-09-2015 12:28 PM
1964Daimler
09-09-2015 12:20 PM
hoodun
09-07-2015 08:02 PM
Quick Reply: 96 XJ6 head gasket
