96 XJ6-where is the Idle Air Control Valve? stalling out on me.
hi my name is jc, i stay in bay area out of cali, this is my first time leaving a message on here, but i always check jaguarfourms if i come across a problem on my uncles 1997 xj6 4.0L and you guys on here are great!!!solved alot of problems with the wonderful and educating responses from you guys. so my problem is when our jag firsts starts up cold start everything is good,once temp reaches more than a quarter of the way i get a missfire p300,and p1314 same code eveytime, we did alot to this jag new plugs,new ignition coils,new maf,new oxygen sensors,replaced precat converters,new engine coolant temp sensor both of them,fuel pressure is good,did orings on the injectors,new egr valve,new head gasket and replaced valves. still same problem. any good advise would be highly apprciated!thanks guys
