96 xjr cuts out on fast acceleration
hello all...i have a 96 xjr...and so long as i drive her easy....she works fine...but if i try to put my foot down to pass (or maybe just because) she falls on her face...its a dead spot and then it willl accelerate ....any ideas on what may be causing this??? Your help is always appreciated!!!
I am experiencing the same thing with my 95 xjr6. If I drive normally it's ok, however, never mind passing gear or getting out of an intersection quickly because it will cut out.cif the engine doesn't cut out because I released the gas pedal quickly enough then it will throw some codes and go into limp mode until I clear them (always refers to catalyst issue)
I'm curious to know if you also experience any intermittent pulsating/feedback of the gas pedal.
I was told by a local jag specialist just 2 weeks ago that it likely is the TPS (throttle Position Sensor) just like jeremiahjaguar stated. I have already started looking for one.
Dickie_L_J_O
09-13-2015 08:44 AM
