96 XJR-poor acceleratiion-Very high fuel consuption-37% TP reading on WOT
hi guys, need your help...bought my 96 XJR about 3 mos ago(japan spec)...worked on the suspension, interior and some paintwork.now im on to the engine...accelerates very poorly and consumes about 3 kilometer per liter of fuel!! replaced spark plugs,fuel filter, air filter and engine oil. engine idles very well with no fault codes..worked on the exhaust system also(no leaks) removed ALL cats..removed slack from accelerator and throttle cable.Using handheld OBD2 scanner, i only get 37% throttle position on wide open throttle. idles on 12.9% at 700rpm.
do i need to replace my TPS or have it calibrated to get those horses out of the engine? any suggestions?
thanks bob,a jaguar dealer here in manila charges too much for a TPS adaptation...i will try to a find another shop who can do it..do i need also a oxgen sensor orientaion after replacing or calibrating the TPS?
shaune (12-01-2013)
Charlene n John
09-28-2015 06:01 AM
