97 VDP: Can bad coolant temp sensor prevent heater from getting hot?
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Only getting minimal heat.
I have not observed the heater water pump (small black cylinder?) running, even when fully warmed up.
I don’t see voltage at its input.
Coolant temp needle never leaves full left (cold) position.
Shorting the single-blade temp sensor wire (at themostat housing) to ground causes needle to tick up, ~one tick/second.
I assume that the little pump does not run until a certain temp is reached?
Is the sensor the likely culprit, or could a thermostat problem keep heat from getting to the sensor, even when fully warmed up?
What’s that other sensor (2-pin) in about the same area, near the thermostat housing? Should I suspect it?
Thanks,
gbmtkj
Thanks,
gbmtkj
Received 10,873 Likes
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Thanks to all for the suggestions.
Doug, the problem did turn out to be the thermostat.
After replacing it and driving about 3 minutes, the temp needle left 'C' for the first time, and marched right up to 'N'.
AND, the heater makes good heat now. I can't leave it on '80' anymore!
Thanks,
gbmtkj
Thanks,
gbmtkj
KarimPA
09-12-2015 08:15 AM
OkieTim
09-08-2015 04:48 PM
KarimPA
09-03-2015 07:32 PM
