'97 VDP drivers' seat issue
Hopefully this will be an easy fix. The only thing that does not function as it should in the car is this: when I open the drivers' door or pull out the key the steering wheel retracts and rises, and the seat moves back. When I put the key back in the wheel returns to its' pre-set position but the seat does not return. Also there is no cheery chirp from the memory switch when the button is depressed. Not a burning issue in the fullness of things since the seat does return to the pre-set position if I adjust it with the seat switch, but I would really like, since it is so close to all things right and proper, to get it to 100% perfect. Any thoughts and/or recommendations ? All input gratefully received.
