97 VDP Sunroof works, but how to autostop at full closed??
Old 05-10-2011, 10:56 PM
gbmtkj's Avatar
Default 97 VDP Sunroof works, but how to autostop at full closed??
The sunroof operates OK, but there must be some trick I need to know with the switch, in order to get it to fully close by itself.
When the roof is open, I momentarily press the front of the switch, and it goes all the way to fully closed by itself, but doesn't stop there! It always continues and tilts open the roof.
The only way I have that works is to tap the button forwards and backwards, until the roof is in the flat position. But this takes getting in and out of the car after each press, to see if it 'looks' fully closed. (or takes two people!)
What am I missing?
I know if I hold the door key in the locked position for more than a second or so, the sunroof tilts open. Is there a similar case where I hold the key in the door a certain way to get the tilted roof to close?
I don't have functioning key fobs, in case they're involved in the answer.
Any suggestions?
Old 05-11-2011, 08:16 AM
Received 8,075 Likes on 4,870 Posts
Here is all the info you should need to time the module.
bob gauff
File Type: pdf
johnnie ryall
10-19-2015 09:44 PM
Mac Allan
10-12-2015 11:59 AM
Aranon
09-03-2015 07:56 PM
ogorir
09-03-2015 07:34 PM
bluerdg
09-01-2015 08:07 AM
Quick Reply: 97 VDP Sunroof works, but how to autostop at full closed??
