97 XJ6 needs front camber adjustment
Received 6,310 Likes
janetbob (05-20-2014)
Received 10,876 Likes
Wheel alignment is an industry within an industry and often comes up with its own solutions to problems on many cars. If there was something out there to address the non-adjustable camber on the X300 Jags then I strongly suspect your alignment shop would know about it via their trades publications, supplies vendors, etc. It's a well served industry.
If the camber is out of spec than something is worn and needs replacing (control arm bushings come immediately to mind) or there's a problem with the subframe (bent, most likely).
Why-o-why Jaguar decided to go with non-adjustable camber is a mystery.
rusty37
04-05-2020 07:40 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
