!996 XJ6 Fog Light Replacement
push the light to one side with one hand while slipping a thin stiff plastic tool in between the light and bumper cover with the other.. this will release the clip on the side of the lamp and it will just pop out ...replace the bulb and pop it back in ...if your real carefull you can use a long thin screw driver ...if you don't have the tool...... just don't pry on the bumper cover
John P (05-14-2020)
rusty37
06-07-2016 04:43 PM
X_Type_South_Africa
12-09-2015 05:37 PM
