!997 XJ6 4.0 ...Radiator resevior has a drain hole
Seems I'm losing coolant through the drain hole, fill up reservoir to max, which is clearly marked in the reservoir. Drive 5 minutes, puddle of coolant? Have not pressure tested the system, as of yet, any starting places? I'm in the US, I love my Jag. But scared to drive it, any and help would be appreciated.
The puddle is always on the drivers side by the front tire but I don't see any leaks except from the drain hole at the bottom of the reservoir tank???
See page 35 of the below doc so you can make a checkoff list
http://www.jagrepair.com/images/Auto...300%201995.pdf
citsalp (01-16-2018)
Will do thanks. I will also update.
citsalp (01-17-2018)
If you are concerned as to what the water temp really is you can purchase this tool from harbor freight .
https://www.harborfreight.com/infrar...er-93984.html\
You would have to test at a couple of points being the water pump body itself , the area just around the temp sensor ( there are 2 , the instrument gauge sensor is the 1 wire ) , and the outlet to the 2 nd electric water pump to the cabin heater that pulls water from the block independent of the main engine mechanical water pump as this would pull out a block sample . You would have to sand the laser target surface to get a accurate reading to compare to the instrument gauge .
The X300's AJ16 engine is robust up to a point
Have you thought about putting a paper towel that would visually show ( blue paper shop towel ) under the hoses you can place under as it is pressurized ?
Any questions , just ask and some one will further you toward a resolution .
Radiator draincock is on the RHS, at the bottom of the RHS Radiator side tank. There is no drain port on the reservoir. It has a nipple on the bottom for a hose connection, about 5/8" IIRC. There is a pair of nipples at the top, front right, for hose connections - maybe 1/4" they are much smaller than the one on the bottom. There is the filler neck on top, and that is it for openings in the reservoir. There is a sensor port on the bottom at the front for the low-level sensor but it is not open to coolant. In other words, you can remove the sensor, with a full reservoir, and no coolant will escape, even under operation at temperature.
Given your description of the puddle, I would hold your b*stard hose and or the coolant rail gaskets under high suspicion.
motorcarman (01-20-2018)
kalexander
01-30-2017 05:13 PM
WTB[MidWest]: 20 Hole 15" XJ6 XJ40 Wheels
DayOff
10-29-2013 05:48 PM
