ABS and error codes
The ABS light's just come on after getting the car charging again ...I suppose it could be a shock reaction to suddenly having the correct voltage on the main bus, but...I'm going into the garage tomorrow to try my Autel code reader. I'm pretty sure it doesn't have Jaguar on it, so, being a '97 ( Ford era ) I'm wondering if it'll read codes as a Ford? or if simple OBD will read the fault... if not ..what are my options for reading codes for a '97 AJ16 4.0l ? is it only the iCarsoft i930 ? ..blimey ,a hundred quid ..she'll hit me with something.
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1300x2000/jaguar_x300_abs_untitled_6e29e9c25095b1c543f31990b8b493a62c5e41f8.png)
Without a code reader the first step recommended is to clean the wheel sensor faces that get metallic debris on there clouding the signal over . Be careful to not try too hard to remove them as they do break . Someone suggested cleaning the rear sensors from the inside of the hub to get around this .
After that you can read the 4 sensor wire pairs as a fundamental reading of about 1300 ohms . If you jack a wheel and spin it in the correct direction you will see about 1.0 volts AC as a true functional test ..
Lady Penelope (06-12-2018)
dsetter
02-02-2024 11:57 AM
jagosaurus
09-01-2013 05:24 PM
