ABS light just come on - brakes are fine though?
Me again with my game old bird of a sovereign...1995 4.0.
My wife has just called to say the ABS light has just come on. The brakes are working fine although have been getting a bit of a squeek from the rear when braking.
I suspect the rear pads are needing done anyway.
Given the brakes work fine and can just about stand the car on its nose if required.
Where do I start looking for a cure??
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Received 2,263 Likes
flying scotsman (06-10-2015)
I was wondering where to start looking? Is there a common fault I should be looking for?
cool (06-11-2015)
The ABS system should reset when the ignition is turned on. The warning lamp will then come on if there is a fault after driving a short distance. There is a known problem with dry solder joints in the ABS control module which is directly below the ABS pump. The attached document describes how to repair.
The following 3 users liked this post by V126man:
Due to some delays, I'm not quite finished with my wheel bearing replacement yet, about 80% done with the second one, but during the whole experience I've had some ABS concerns too...
My ABS light has been on for years, I ignored it because one of my local indie shops said don't worry about it, brakes will just work as brakes without ABS... not sure how much of that I believe nowadays.
Anyway, while replacing my wheel bearings, I noticed that my speed sensors were completely choked up with brake dust/grease. They're clean now, but I haven't finished the job and got back out on the road yet. I have wheel speed sensor codes showing, which I hope to be gone once I'm done, but the "dreaded" C1095 code may need addressed too, by way of a soldering repair inside the ABS control module...
That ABS module is apparently notorious for problems, with a very easy/cheap solution, so it might be worth looking into.
It's the ABS module.
Bumping. rattling and jarring while driving-eventually the two welds ( read up on 'em ) crack and need repair or replacement-did mine again TODAY! :-)
I've only had a similar issue 4 times.
And I GUARANTEE you the idiot light will return.
It's not if....it's when.
THere are lots of posts on the problem.
Fear not.
Fear not.
My ABS light was on for 5 years, and a local indie Jag shop said it was no big problem, so I ignored it cuz the ABS light is hidden by the steering wheel.
Another indie shop told me it would be a $2000 fix... I'm Scottish, so good luck getting me to pay that!
But, recently I had multiple ABS & chassis codes, so I decided to bust that module open and follow all the sage advice of our Jag elders, and HFS... it's 100% true.
Assuming you're sufficiently skilled and confident, bust it open and solder those 2 joints. Then bask in the glory cuz it's really that simple of a fix.
al_roethlisberger (06-26-2015)
innzane
09-02-2015 10:08 AM
