abs light OUT
abs light OUT
Thanks to aholbro1 I quit screwing around, pulled the module, drilled a 1" hole over the pins, scraped off the insulation and soldered the pins. I used 2% silver solder with a touch of flux, which I then cleaned using wet qtips.
I still need to bleed the brakes and epoxy the plug in place, but at least the aggravation of trying to locate the problem without proper diagnostics is over.
RJ, Most humbled but you mean thanks to Bob! He posted the "how-to" - all I did was add my experience of needing two tries at the soldering to get it right! Scared me when he told me to just bend the brake lines, too....but it really wasn't bad at all - and they go right back in place!
BTW, have you driven it out past where the light normally illuminates yet? I couldn't be sure I had a real fix until I got past my neighbor's house without a light....
aholbro1, it was you telling how the alarm came on after about a hundred yards that made the decision. I had already repaired the XK8 module and knew how to do that. I'm still not sure how motorcarman separates the module from the hydraulics and doesn't have to disconnect the lines. I just took the whole thing out and then removed the two screws on the bottom.
Anyway, I drove the car a couple of miles yesterday and no light, so it's fixed.
Loosen these two hex nuts on the front, and an identical one on the back, and you can lift the entire module-pump assembly out:
Here are a couple of shots of my brake lines after I "bent" them to roll the pump module up, forward, and inboard to remove the ABS control module, then put it all back together after mending it. If they were permanently deformed, I can't tell it:
The following 2 users liked this post by aholbro1:
Don B (03-29-2017),
motorcarman (10-13-2013)
When you get paid a set amount to repair a component, eliminating a step (like bleeding brakes) is saving time (making more money).
I dislike bleeding brakes anyway so saving this step is better for the painted surfaces that need to be cleaned IMMEDIATELY!!!!!
Car owners can take all the time they want but repair shops need to be quick and efficient. People want their cars back ASAP from the mechanic!!!!
Zane, I remember that module I had repaired so I will swap that one and repair the faulty one.
I'll look for it in my 'STACK-O-MODULES'.
bob gauff
bob gauff
Don B (03-29-2017)
rsa760041
23
09-25-2015 01:33 PM
innzane
09-02-2015 10:08 AM
