ABS Speedometer Help! 1997 X300 XJ6
History
Initial problem was solid intermittent ABS light.
I disconnected module harness checked my ABS/speed sensors.
The problem got worse solid ABS light on start-up no speedometer.
I had the codes read came up with right rear speed sensor and ABS pump failure. Unfortunately, I did not get the corresponding code numbers.
I changed my ABS module and rear sensors. Initially the ABS light was off on start-up still had no speedometer. The ABS light came on after driving 20ft.
I am now back to the original solid ABS light and no speedometer.
Any advice would be greatly appreciated.
I do have an ABS pump I did not install due to the module being the usual suspect.
Umm is the other needles working on the speedometer? On my 96 XJR my ABS Light was on and Trac is Off and my code was ABS Pump Circuit Failure (c1095) . I plan to take out my module and send it to repair somewhere in dec so im unsure if this will indeed fix the problems, but i did alot of research on this particular code and it seems like rebuilding the module has proven very successful.
First thing i would recommend is cleaning the wheel speed sensors
Heres a Link It should be similar for our x300, or maybe even easier.
https://www.jaguarforums.com/forum/x...ors-faq-37434/
The Speedometer operates from the LEFT REAR sensor! so clean that one up first and maybe it will solve your ABS Light and Speedometer
Second thing is since you already replaced the ABS module, was it with a brand new one? or another used one?
the abs module is known to fail in our cars and it is required to be rebuilt or re-soldered.
I believe the speedometer is driven by the left rear sensor, could he have been mistaken? It is very possible the connecting cable to the sensor has a internal break.
Don't worry about the pump circuit until you have the speedometer working again, it's usually just the solder joint to the pins that's bad, easily repaired.
My experience with C1095 is that your ABS light will be off on every start and come on after some small amount of driving (mine was more 30-50 yards than 20 ft. Whatever is killing your speedo is likely causing the ABS to stay lit all the time. But if you had the pump code...you are probably looking at a re-solder there; could be two problems.
Received 10,906 Likes
It's a the cable that connects the sensor to the wiring harness, available from dealers, etc, or often on ebay.
Jaguar XK8 XKR ABS Speed Sensor Long Rear Wire 97 98 99 00 01 02 LJB3410BF | eBay
42Ajd
12-30-2015 09:45 AM
