ABS/TC Problems
Guest
Posts: n/a
Hi All,
I own a 1995 XJ-12, I've replaced the rear brakes, and checked the play in the rear hub bearings. After assembling the rear hubs my TC lite came on. I checked the resistance of all the wheel sensors, every one is within limits they are all putting out nearly correct AC voltage and it is getting to the TC/ABS ICM. But the light still stays on. Any idea's Thanks Kenny
Guest
Posts: n/a
Hi thanks for the reply, I did clean them, adjusted the wheel bearings, took voltage output readings, ohm readings...everything. Thanks to JTIS and a lot of reading, the throttle cable from the pedal to the actuator motor was way out of adjustment. After adjusting both halves of the throttle cable, and a short test drive, LIGHTS OUT!!!! And they are working properly after a few tests!
Kenny
Kenny
dragonfly777
Regional
09-08-2015 01:39 PM
