ABS Wheel sensor problem
I had to replace the L/R hub carrier and hub, so I had to remove the ABS wheel sensor. It was working fine but after reinstallation in the new hub carrier, I get several warning lights and the speedo does not work. How do you test the sensor? What is it, photo-diode, hall sensor?? Can it be checked with a vom, or is a scope necessary?
BrentGardner
28
04-26-2024 03:08 AM
NinoGrimace
08-26-2015 05:15 AM
