Advice on Coolant
Hi,
As some of you may be aware I am working to resolve some rough idle and high fuel consumption issues on my XJR6. As part of this I have replaced the thermostat and lost some coolant, which looks pretty dirty.
I am going to flush the old coolant out and replace.
Do any of you have any recommendations of what to use?
I am in the UK so brands maybe different. I know a lot has been written on forums about coolant, however from what I can see:
There was a change in 1997 to use Jaguar branded DOW D542 coolant, which is expensive, but I can source. Earlier vehicles in the VIN range 720001-803241, could use this too.
Some people say use G-O5 coolant which is a H.O.A.T. coolant and is a similar spec?
Others are saying to only use a silicate based coolant and replace every two years, which wouldn't be a problem.
This is a bit of a minefield, I don't want to use anything that will damage the engine longterm.
Thanks,
Nick
Thanks,
Nick
I suppose a lot depends on what colour the coolant was that came out. Green and orange do NOT mix. If you are unsure then it probably means a complete empty and flush until you get clear water flowing out then replace with your own preference, I ran 50% water/Glycol in my AJ6 and am using the same in my AJ26 S/c as that is what the repair shop used when they replaced the tensioners prior to my purchasing the car.
Don B (01-21-2018)
Nick, the original was BLUE, WHICH WAS NO GOOD.
Jag found out they were eating away at the heater core.
They went to orange after that, not green.
Red was a gm that was only good for their cars.
Orange or green are good but don't mix.....either or.
Did we do the gtjoey tune up yet?
GTJOEY
GTJOEY
Hi All,
I drained the coolant today and flushed it three or so times with de-ionised water. Each time there were lots of what my daughter called bronze glitter in the water (rust I presume). After three flushes it had decreased substantially and I had run out of water! So in went the coolant. I used the Jaguar D542 coolant which replaced the green coolant that apparently was damaging the heater matrix.
Let's see what happens...
Nick
Nick
Don B (01-21-2018)
Received 10,872 Likes
FWIW, I ran my XJR/6 for 171k miles using old fashioned, off-the-shelf, green "Prestone". Nothing bad ever happened. Well, not with the cooling system, at least!
Don B (01-21-2018)
