Aftermarket ECU + wiring loom /PVengineering+ Swallows Racing
PVEngineering and Swallows racing have co-operated to create loom and ecu package based on Maxxecu platfrom (included is the "street" version)
IF I have understood correctly on the description the one needs anyways to replace lambda to the included bosch 4.2 (meaning welding M18 boss to the to the exhaust). Other things to be taken in account is that Maxxecu does not support MAF based, "only" speed density and alpha-n. Also automatic gearbox control needs to be solved or one needs to spend more money and go to the Maxxecu pro version that has 4l80E control in build.
more info below for those that are interested
https://www.p-v-e.co.uk/projects/aj1...-ecu-packages/
https://swallows-jag.co.uk/aj16-plug-play-ecu-loom/
https://www.maxxecu.com/
interesting tidbit is that the
that has AJ16SC + turbo in it is using Maxxecu.
Austin7
General Tech Help
09-25-2016 10:22 AM
