Aftermarket stereo fitment to Harman Kardon system
Hi all
Just wondering if the Harman Kardon system has the same Jaguar>ISO connector as the standard systems? The lead I intend to buy on eBay says -
'Please note this lead is for the NON-AMPLIFIED systems on these vehicles only. If you are having trouble identifying this, please contact your local dealer.'
(it's eBay item number 150847265021)
Many thanks
Dave
Many thanks
Dave
No I don't believe a standard ISO connector harness will work.
You can easily fit a modern head unit to work with the existing HK amp. You will need to wire or splice the pre-amp outputs, signal ground and shield to a 6 way DIN plug or the DIN plug wires to the harness. Unless of course your harness already has that configuration.
42Ajd
12-30-2015 09:45 AM
FS[MidAtlantic]: 1997 XJ6 VDP - Very RARE Black on Black
42Ajd
09-21-2015 07:37 PM
