Air conditioning pressure switch
Yours is the same as mine, RHD, so it is on the aluminium tube just inboard of the brake booster, 4 wires out the top, commonly called a "trianary switch".
Apparently it reeked havoc with the thermo fan operation in the early days, which Jag worked around with a "loop", to have the fans ON whenever the ign was on, or the a/c was on. I have redone the thermo bit to mine, and will one day figure out the other work around for the a/c circuit, and put it right. A new trianary switch will be required.
speedyxjs (12-17-2010)
Turftech (12-14-2010)
