Is the AJ16 Engine a Interference Engine ?
Although my engine is fine I was always curious if it was more then 2 teeth off or maybe 15 degrees one direction or the other
This is for VVT considerations where the chain is installed in it's proper factory position for a VVT at rotary actuator neutral
Parker 2 (07-08-2020)
https://www.jaguarforums.com/forum/x...e-head-149032/
https://www.jaguarforums.com/forum/x...valves-211876/
Rogelio Serrano
04-27-2017 05:16 PM
