Alarm sounds after door lock on '96 VDP
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
1996 Vanden Plas
I've searched the posts for this with no luck so far so I ask for advice on this one.
My alarm will sound about 30 seconds after locking doors. After locking and re-locking several times checking to insure all doors and trunk were securely closed I discovered that:
1) After depressing the locking button on the key fob, the sounder announces the car is locked and security is engaged. 30 seconds later the alarm sounds - shuts off properly with the open button on the fob.
2) Then I lock the car again, same steps, and after the normal lock/alarm beep, I get a single short chirp. (It is the same sound one gets if a door or the trunk is not closed.) If I get this new tone, oddly, the alarm does not sound.
Of course, the alarm "misfire," and that second chirp upon second lock attempt are the puzzles here.
The first thing I did, of course, was check to make sure all the doors and trunk were closed tightly. Then I replaced the battery in the fob.
No change.
I was going to try our second fob, but that one seems to be temporarily misplaced.
Note: I should add that this happened on the first sunny day after a couple weeks of drizzle and a day or two of pretty heavy, constant rain. It has had plenty of sun and time to dry out though if that had anything to do with this issue.
Before I take it to the dealership for expensive diagnostics, I am hoping someone here has had a similar experience.
Thanks for your expertise,
Tom
No change.
Tom
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
