All dash warning lights flash 1997 xJ6
hello,
I'm new to this forum but going to start with electrical issues with my 1997 XJ6. I had a 1995 XJ6 back in the 90's and nothing good to say about that one. The 1997 XJ 6 was purchased new by my parents and has been fairly reliable other than burning a valve and rear end issues that cause for a complete rebuild.
Problem now is all of the dash warning lights flash at times and the gauges go from reading to zero. Car does not mis a beat but when it first happen, it cared the hell out of me. Got to my mother and parked it until today. First though about a grounding issue and checked the grounds in the trunk and all is good there. Never had the cluster out nor know how it comes out but need some direction. Help! Thanks car has 192,000 miles.
Received 10,975 Likes
It's almost a certainty that you have one or more ignition coils starting to fail.
Figuring out which one can be a problem. Remove the coil cover and run the car in a dark environment. If the problem occurs, the faulty coil will sometimes reveal itself by a visible flashing in the opaque epoxy at the top. Unfortunately, lack of flashing does not prove a coil is good.
I urge you to buy true OEM replacement coils....the ones made in Japan by Diamond Manufacturing. Many of the alternate brands do not hold up well.
The correct area to post questions for your car would be the "X300" section
Thanks, I will try to post in the proper section next time. there is a random misfire that says coil. Never had all the wording lights flash from a bad coil before and All of the original coils have bee replaced at some point with aftermarket. Thanks for the tip on the coils also. 1997 has OBD II and the misfire cylinder should show on a scan
The OBD II on these X300 cars wasn't the greatest at misfire detection. I've disconnected coils on a running engine and still no code.
The instrument panel insanity being caused by a bad coil is a bit weird, yes. I never woulda believed it if I hadn't been thru it myself!
Photoman327 (02-09-2015)
In all the years of reading/hearing about (and experiencing) the instrument cluster craziness the only time I've ever heard of it *not* being the coils it was a TCM failure.
I can't recall how the TCM was isolated in that case, sorry.
Did you get the bona fide OEM coils made by Diamond Manufacturing?
99xk8guy
06-05-2023 06:28 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
