Alternator Bearing Bad
Any recommendations on a new alternator ?
When starting up Penelope the alternator squeals
Belt tension just right
pully on the front of the alternator warm and getting hot
The alternator is from a salvage yard and was putting out 13 or so volts on engine runs a couple months ago ( was able to punch the throttle to get the squeal away then )
Now the search for repairing the existing or get another one from a salvage yard as a cheaper then new and their reliability
I cracked a on another one the alternator aluminum casing halves so I don't want to go down that road again
I see the front bearing part list though
Bearings for Nippondenso Alternators (alternatorparts.com)
Received 2,692 Likes
You'd be better off if you took the alternator off the vehicle and had a local automotive electrical shop overhaul it. Quite often, the units purchased from a parts house have issues interfacing with the vehicle's electronics and may cause the charging system warning lamp on the instrument cluster to remain on.
The following 2 users liked this post by NBCat:
motorcarman (12-22-2021),
Sheff928 (12-23-2021)
Now that you mentioned it I do know a large alternator shop in town I've been to before and they can swap out the bearing knowing it was cranking out good voltage before
Thank you for bringing that up as I have seen the reliability issues
The one I have is an original Denso and I have a brush kit for installation now or later
I've tinkered with this ones brushes before so they are easy to get to
I can also get a good test bench spinup before installation
The local shop I use (https://www.facebook.com/highviewrebuilders136/) uses DENSO rebuild parts.
Always function normally when I get them back.
Whittled the alternator out of the car , old hat as was done before with the original alternator when that one time I hooked the battery up backwards and fried the voltage regulator
Off to the alternator shop
I was angry and frustrated at the time so now I have a arrow taped on the top of the battery pointing fwd
Cafcpete (12-24-2021)
Alternator was taken to a alternator shop to change the bearing only and it may prove on test bench to be bad in other aspects
Found a new and not rebuilt alternator unlimited lifetime warranty at local parts store for $ 239.99 - core charge so I can't beat that price but reliabilty is the question and the number of changing it back out
Thanks Xalty ,
but bad link
In the time frame I have to work with I can't ship it off somewhere and get the car running again within a time frame
Someone else may use the vendor link in their alternator options
If it was rebuilt by Denso ( or monitored by ) they would most likely have higher standards then just changing a single part to enable to just get it out of the door as cheap as they can
but bad link
watto700 (01-01-2022)
Verifying vendor Denso number against original Denso that came with car ( broke casting when trying to separate the 2 halfs as I fried that one but saved for parts )
Off the top of my head there was a different Jaguar part # for the supercharged engine for what ever reason
Mine is not supercharged
Combination Jaguar / Denso label
Jaguar # DBC - 6819 and is a match reference website below
Denso # 10 - 0211 - 63x0 ( label damaged )
The 2nd alternator extracted from a salvage car and presently away at a shop may be a different # and everything may match the vendor website as my VIN is 75xxxx
Part # reference source :
Genuine Alternator Assembly For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
LNA1800BA for the supercharged reference the above website
The only difference in the cars operating requirements is the supercharger intercooler electric pump being on imediatly after start up
The alternator is 120 amp across all X300 models from my understanding
So we have a combination of deferent Jaguar part #s even within VIN #s
