Alternator Diagram
Alternator Diagram
I am helping my friend get his 1996 Jaguar XJ6 back on the road after many years of down time. We actually got the car started but it does not have an alternator installed on it.
I can see three wires and a plug which he says is for the alternator. The plug and the wire with a boot on it I can easily figure out where they go. There are two remaining wires, ones with a big ring on the end and one with a small ring.
Can someone please inform us where these 2 wires go? A diagram would be amazing. Also can someone tell us what voltage, if any, should be at the wires and when they should be there.
Thank you so much,
Mike
Thank you so much,
Mike
The round connector is to the voltage regulator plug on the back of the alternator assembly
There are only 2 wires in a 3 wire plug
The 2 small separate wires go to the noise suppressor mounted lower by the alternator and is a black cylinder
The large terminal post ( B + ) should read at least 13.5 volts with the alternator turning
Editing
There is a fuse for the alternator excitation
Editing
The following 3 users liked this post by Parker 2:
Editing
Editing
So you are saying that only the booted wire goes to the big terminal and (obviously) the plug get plugged in.
I can see the single wire that has a small ring end terminal be for the noise suppressor but the other wire has a much larger end ring terminal that actually can fit over the big terminal. Can I just not use these two wires?
Same question here. What do you mean by black cylinder? Where is the black cylinder located? I think the smaller ring terminal wire goes under the right lower nut shown in the picture above and is the ground for alternator. The question is where does the 2nd smaller wire (not the booted wire) with the larger ring terminal hook up? It will fit over the larger b+ terminal where the booted wire goes but that doesn't seem right. It is obvious that the booted wire goes to the b+ terminal shown above in the picture at top center and that the plug will only fir into the socket shown in the picture above on the top a little to the left. Where does the second larger ring terminal wire hook up? Any help would be appreciated!
Parker 2 (08-20-2020)
This is the noise suppressor with the 1st side of a oval connector . Another oval 2nd side connector plugs into it containing the 2 short wires with the eye terminals
This suppressor is located under the car near the alternator
The question on large and small eye terminal placement will be looked at in a bit
Don B (08-20-2020)
1996Jag (08-21-2020)
The parts catalog implies that the "Supression module" was part of the optional "premium in car entertainment" package.
https://parts.jaguarlandroverclassic.../brand/jaguar/
In any case, based on the nice picture above supplied by Parker2 here is how it goes. The wire with the small ring terminal goes to the bottom LEFT terminal (at least on mine). The wire with the big terminal as I thought goes to the battery stud that the booted wire also goes to. I know that someone else said that the small terminal wire goes somewhere else but I am 100% sure that it goes to the bottom left terminal on the picture above.
I hope that this helps you.
Jomo
piper 888 (08-24-2020)
Adrie
XK120 XK140 XK150
11-04-2013 12:53 PM
