Ambient sensor reading
Old 06-21-2019, 06:03 PM
cdma's Avatar
Default Ambient sensor reading
I was looking at the outdoor temp and it was about 20 degrees off. Does that mean I need to replace the sensor or is there something I am missing. I am not sure if I kept it off my parts care if that is what it is.
Old 06-21-2019, 07:43 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
Old 06-21-2019, 08:19 PM
katar83's Avatar
Nah, it means that the plug under left wheel arch liner at the front is corroded. Remove the liner around the bumper and you'll see a large plug/socket. Clean each pin hole with a 1mm drill and the pings with some contact cleaner and it will show correct temp again.
The following 5 users liked this post by katar83:
944play (01-19-2021), Cafcpete (06-27-2019), Lady Penelope (06-21-2019), littlelic69 (06-27-2019), Scotlad (06-24-2019)
Old 06-24-2019, 07:04 PM
cdma's Avatar
That was it. All working
Krisfx
01-18-2022 06:07 AM
yachtmanbuttson
09-08-2018 12:23 PM
Pete Type X
05-14-2018 05:35 PM
mjlaris
10-15-2012 03:34 PM
ThomasElliott
05-01-2008 06:15 PM
Quick Reply: Ambient sensor reading
