ambient temprature sensor issue
So, i had error code 12 on my climate control, whet to investigate and realised that not just the sensor was missing but the entire brake duct.
so i purchased a second hand unit, finally got around to installing it,
cleared the codes on the AC,
but damn, no reading from the sensor “- -“ is all i get.
the error code has gone so the sensor has continuity and is completing the circuit, if i unplug it the code comes back,
But the sensor is not working.
now before i buy a new one, is there anything i am missing? Anything i can try?
and if i need a new sensor, does anyone actually know anywhere that has new ones? Preferably Aussie, but will buy from overseas when i need to.
The sensor is a thermistor ( semiconductor ) that needs power from the testing meter to the device to read correctly , this is different then a thermocouple that is reading resistance through the device
This means you can't use a pocket 1.5 volt test meter
The calibration chart is on page 100
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
http://www.jagrepair.com/images/Trai...des/703_SG.pdf![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
like i said atm all i know is the circuit has power as it lights my little led test light, and the sensor completes the vanishes as my error code vanishes.
Since the chart is for return voltage to the climate control ECU ( your meter in reading voltage does not supply power to test the device ) you would use a different method
You can nick the insulation on the X color wire as the connector is connected
You would have to use a very good ground stud
Do you have a noise suppressor ( long cylinder under the car by the alternator) not installed in the same area as you may be hooked up to a spare connector ?
The noise suppressor is hooked up to the alternator with a connector in between and all X300s came with them
but i must be connected to the right plug as it comes from the correct connectors, with the correct colour wiring, and connecting to it removes my climate control error code.
as far as testing hoes, interesting as i noticed there was a nick on the insulation on the wire and i thought “thats odd” but of the wire a has been nicked it would stand to reason that the wreckers tested it. And if they tested it i assume it worked before they sold it.
probs gunna be the weekend before i can get back under the car.
The nick has to be resealed as is very prone to corrosion under there
It may already be compromised and miss leading as calibrated correct reading to the climate control ECU
The nick most likely came from the previous owner that had issues so that would make the sensor suspect
valid connector hooked up makes sense
if the sensor is busted finding a new one is probably a PITA and buying 2nd hand is always a crab shoot.
Parker 7 (01-16-2022)
btw, seeing as how helpful you are, did you see my thread regarding gear shift interlock. Lol…
