? Andy's front Droplinks experience
Old 11-22-2014, 03:41 PM
weisberg's Avatar
Default XJ6 rear end to be tightened?
Once the links are installed on an XJ6 (not the sportier XJR) and the front is effectively tighter, should the rear be modified in some way?
I just finished an hour of tight mountain canyon driving purely for the fun of it, and the stock XJ6 can be brought to oversteer quite readily, which is fun although with the drop link upgrade I wonder if it would become tail happy in such relatively rare circumstances.
I don't know yet if XJ6 has rear anti roll bar, or if one can be added readily from say an XJR or UltraRacing
Old 09-10-2016, 01:22 AM
XJRengineer's Avatar
I've added this post to bring this thread to top of the list by recent reply, as Wayland asked about it on another thread.
Old 11-11-2016, 07:18 PM
michaelmedina2005's Avatar
i installed my,"andy droplinks",today,tomorrow,I will do the test drive,also,i installed front and rear swaybar bushings of 85a shorestrength
XJRengineer (11-12-2016)
Old 11-13-2016, 10:36 AM
ok,i did the test drive,I am very pleased with the results of the drop links along with the 85a shorestrenght sway bar bushings.great combo,delivers great results.much improved handling on a twisty canyon road.i also have a monostrut ,i will also soon replace those bushings as well.i am very happy with the,"andy droplinks",and the,"andy 5 degree advance bracket",the car is better than ever,next stop, are a full set of bilstein b6 shocks...
The following 2 users liked this post by michaelmedina2005:
Don B (04-15-2018), XJRengineer (11-14-2016)
Old 11-14-2016, 10:38 AM
Thanks for the positive feedback on the drop links. To get the most out of these drop links does require stiffer bushing, as you have done. Do you know how your 85a shore hardness bushes compares with Powerflex bushes
FYI
Jaguar specified stiffer dampers on the German spec cars. You may still be able to order them from a Jaguar dealer in the US, as an alternative to aftermarket dampers.
someguywithajag (11-17-2016)
Old 11-14-2016, 11:44 AM
AnttiM's Avatar
Isn't Bilston b6 or b6hd the oe for German version anyways http://www.jaguarclassicparts.com/il.../MNA3540EB.jpg at least it is bilstein in the illustration
Old 11-14-2016, 12:09 PM
FYI
the powerflex street are 80a,race are 95a,i am happy with the ones that i made....but,it would have been much easier,and less mess, to just buy the powerflex,i like the way they are textured in order to retain lubricant.i also textured mine but not as good as the powerflex design,nevertheless,i am pleased with the results...
  #28
Old 11-16-2016, 04:45 PM
al_roethlisberger's Avatar
Quick question: What technique do you use to make sure the lock nuts don't loosen and allow the central tube to turn, loosen and change the length of the assembly?
One could use thread locker, but have always wondered if just tightening these nuts was enough, especially considering the constant vibration.
Old 11-19-2016, 01:31 PM
I tighten the nuts against the turnbuckle to keep them in place. I have had these drop links on both my cars for many years and they have not come loose. You could choose to apply thread locker.
al_roethlisberger (12-02-2016)
  #30
Old 12-02-2016, 03:22 AM
paulXJR6's Avatar
Could someone tell me the correct size front anti-roll bar bush for an XJR please? Powerflex quotes 3 sizes; 22mm, 24mm & 25mm?
  #31
Old 12-02-2016, 03:48 AM
someguywithajag's Avatar
25mm. I installed kit#PFF27-405-25 (the '25' stands for 25mm) in mine. I used a pair of calipers to measure the thickness of the anti-roll bar first too
The following 3 users liked this post by someguywithajag:
Don B (04-15-2018), paulXJR6 (12-02-2016), XJRengineer (12-02-2016)
  #32
Old 12-02-2016, 08:03 AM
I measured the front anti-roll bar on my 95MY UK spec XJR6 to be 25mm as well.
The following 2 users liked this post by XJRengineer:
H20boy
07-23-2021 09:39 PM
weisberg
03-25-2021 05:47 PM
johndahlheimer
09-16-2015 05:44 PM
KarimPA
09-12-2015 08:15 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: ? Andy's front Droplinks experience
