anither few questions
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
another question for you guys. Why does the D indicator go red or normal when in D and you flip the stick to one side or the other.Also whats the sport switch do?Mine dosent light up and i really dont notice a diffrence in anything,i pushed in the sport button on the freeway and the RPM's didnt change......
I don't have a sport mode on the 3.2, but as I understand it sport mode will let it rev higher before shifting. If you were cruising in tp gear at a constant speed, then switching to sprot mode shouldn't make much difference? If it doesn't light up then that probably means the bulb is just blown.
Received 10,879 Likes
The sport switch can be carefully opened up and the tiny "grain of wheat" bulb replaced...Radio Shack or similar has the bulbs. This is for backlighting only. When the switch is flipped a green "Sport" icon should appear on the instrument cluster.
You should notice quite a difference in shift points with/without "sport" mode
No "sport" light in the dash comes on. The only light on the dash is traction off when I turn the traction controll off. Also the car sometimes won't come out if park till I **** with tilting the wheel up and down. Starting to find the little stuff now. Plus the check engine light just came in but runs fine still.....
