Anti Lock - intermittent
Sometimes, whenever I drive about 50 ft or so, my anti lock light comes on and doesn't go away until I turn the car off and then start it back up and it's gone.
Sometimes it won't come back after driving and for the past 2 days the light hasn't come on. I inspected the front sensors and it looks like there is a ground wire on the driver front that is no longer connected.
Would that ground wire be the problem? I've tried looking online for replacement sensor cables but none of them seem to have the ground wire connect so it makes me wonder.
Received 10,910 Likes
I believe the code was C1095. I think he said the ABS control module is failing.
JonnyO (06-18-2012)
It's weird, since I took off the wheels and found the cut ground wire I haven't gotten the anti lock light.
If it does come back, what I am going to do is cut about an inch of the rubber boot off and see if that's enough to connect both ends back together.
Either way, I will let you know how it goes.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
