Anybody know how to change the ignition key tumbler?
I posted on this quite some time ago. I don't remember the details, except that to remove the actual barrel, you leave the key inserted and depress a small lug on the underside of the barrel and pull on the key.
A search of my posts should uncover it and the accompanying pics. Be aware also of the black rubber ring at the front end of the barrel, which reads the signal from the key chip. Unless I'm mistaken, any (xj6) key will fit, but won't be recognised and will have to be programmed by a main dealer.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
jagent
09-12-2015 01:40 AM
