anyone upgraded X300 brakes?
My XJR had new front discs and pads a year ago, and they're fine under normal driving.
But I have a short local road circuit which has twisty sections, and it's easy to fade the brakes after 3-4 miles on the twisty bits. I don't think the discs are genuine Jag, and this may be a factor.
I have contacted racebrakes.co.nz in Auckland, and if I send them a set of old pads, they can re-line them with a hotter compound. I have yet to do this.
I have seen some dimpled, slotted rotors for the X300 on the internet , which may help.
Has anyone improved their X300 brakes, and if so is there an easily-available upgrades in terms of discs/rotors, and pads?
It makes sense to upgrade the brakes if you often have a mountain drive. Switching to DOT4 brake fluid, upgrading to stainless steel brake hose, racing pads, bigger rotor, and finding crossed drilled and slotted disc, and perhaps using tires that stop faster are all part of the formula (here is a good article on this topic)
The Consummate Driver: Myth of Big Brake Upgrades.
However, would also like to know like you just asked if anyone had any good experience in this. I presume there isn't much after-market products tailored for the XJR6 market, especially now that the model is about or more than 20 years old.
EBC pads are pretty good all round ,
Green Stuff is good if you drive hard around town - good for up to 300 C or 570 F
Red Stuff however , will do most track days and around town - up to 500 C or 930 F
Blue and Yellow Stuff will need to fitted at the track - can't get hot enough to work normally .
I would suggest a chat to DBA in NZ or NSW regarding rotor selection . You would need minimum SERIES 4 or 5 THOUSAND ROTOR type to handle the heat .
Cheers ,
Cheers ,
The following 2 users liked this post by dfieldsend:
overtheatlantic (05-18-2016),
someguywithajag (02-03-2023)
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I ask because I've bought SS lines from other mainstream vendors in the past that were said to be an exact fit, but turned out to be "close" and sometimes "close" wasn't good enough. Some had odd fittings that required adapters at the caliper or hard line end, the lines were too short/long and bound or rubbed, didn't have or accept factory strain relief or mounting locations, etc...
oldish git
27
07-24-2020 02:05 PM
hisport
04-09-2016 08:40 PM
al_roethlisberger
04-09-2016 03:50 AM
