bad fumes smell, not very good consumption, not good enough temp
That rattling noise sounds like a dead water pump. Mine sounds just the same.
Take off your water pump belt and turn the pump by hand. It should turn nice and smoothly, and there should`nt be any play when tackling the pulley. If the pump turns roughly and pulley has a play in it, replace the water pump, before you overheat your car. You can do the same with the alternator, it also can become noisy, when bearings are worn out.
Andreas Pavlos (03-25-2018)
Sounds like you have a dead O2 sensor. The original equipment is NTK brand, they work well. Don't use a "universal" type sensor, as the Jaguar system uses a unique type of sensor. The only difference between the two sensors in the car is the length of the wire, the plugs are the same.
An NTK 25018 will work in both positions. You'll need a 17mm wrench to get them out. I'd replace both while you're there.
![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
![Icon Wheel](https://www.jaguarforums.com/forum/images/smilies/icon_wheel.gif)
![Icon Screwy](https://www.jaguarforums.com/forum/images/smilies/icon_screwy.gif)
maybe yes maybe not i replaced the one i decide to do so and i will go test the car. it smells for sure better!
some photos and video follow and my tools
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
https://drive.google.com/open?id=1Pz...OyogiMH8vzX8gk
thanks for the advice everybody and the help!!!
The pic is on post # 12 and the wire color is the one with the dasher wire shielding . The earlier AJ6 engine cylinder numbering is opposite the AJ16 . Have you cleaned the shield grounds on the firewall as this is a very sensitive intelligence O2 signal it protects .
Ask questions
Ask questions
Ask questions
Ask questions
i havent done anything inside the engine bay for as long i own the car...
#30
#31
Ask questions
Ask questions
a comment: last week i was getting myself when i was opening the drives door in order to get out of the car while engine is on a "spark" in my hand, like getting out of wool clothes... after couple of days my sub went dead i assume is a fuse i will check tomorrow by replacing the fuse.
At the same time on new coil makes sparks if its not tight on the block. after asking the coil seller (a lucas one) if its broken he said something about electric problems that may ignite this problem. i can comment the email from him in case that helps.
so maybe its something deeper and not just a O2 sensor; just thinking..
No errors at the jaguar workshop but in the past they couldnt find any errors when i had rough idle and bad consumption. we replaced several pieces but nothing helped. in the end i fixed my self by replacing some of the coils. the scan is suppose to show coil errors and even though i had t didnt.so...go figure
now my consumption looks fine on the highway (500km at least) but inside the city at best case is 25l/100km up to 35/100 do u believe this is normal; maybe cold weather; (-5,-10) today is sunny and +4 after driving the car for 20 minutes i didnt notice the huge amount of smoke from the exhaust neither the smell...but again, its +4 ..bad timing for testing
#32
well i have the sensor but i cant find where the downstream is located. i can see 2 one per 3 cylinders from the engine bay top, but where is supposed to be the third one or downstream; mechanic said i should have 2 but these 2 i can see are both at the same level of the exhaust manifolds.
#33
25-35 L/100km is way too high unless you're doing a lot of idling.
#34
The pulley is the circular metal thingy on a water pump on which the belt runs. Loosen the alternator tensioner (metal rod with thread with bolts on it), take the belt off and twist the pulley with your hand. This is how your water pump looks like.
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x750/sng_feb17_ebc10967star_c9085da7aa2542d3613d6afa50d8ae351a4d4040.jpg)
#35
well i idle a lot since its cold i have some brakes inside the car. Is that much fuel consumotion on idle?? I thought the opposite !!
#36
KCooper167
36
01-30-2015 10:36 AM
