Ball joints
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X300 forum. Advice / Feedback & Suggestion Center is for posts about the forum and not for technical questions.
Members here with the same model will be able to help.
You should add detail on whether you are asking about upper, lower or both.
Lots of price variation on the ball joints, you can get them for anything from $20-100 depending on brand. Factory spec lemforder are about $50.
Pretty easy job to replace both lower and upper joints and tie rod end, just be careful when you break the tapers as the hub will kick out.
Make note of the location of the shims on the upper joints as they control castor.
Camnelson324
09-27-2015 08:48 AM
Woznaldo
09-26-2015 11:02 AM
