Battery hooked up backwards !!!
Old 02-24-2018, 04:55 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
Mileage display ?
Old 02-24-2018, 05:49 PM
shorty one's Avatar
odometer mileage lights / works
maybe yes,...... seems very faint and black
so...probably no
I did not hear or feel any relays picking up.
Except, randomly/ intermittently would hear one from the driver side kick panel click repeatedly when the drivers door would open.
interior lights work
door chimes
power seat and steering wheel automatic driver settings 1,2 and 3 when key installed
front head lamps come on and off when door locks cycle
Old 02-24-2018, 07:19 PM
Remove the lower steering column cover to access the ignition key connector and take pin 3 on the car side to a ground and feel for king relays RH and LH Heelboard and RH Engine fuse box to click
Take pin 2 on the car side to ground and feel for king relay Trunk fuse box to click
Clean and verify the car side ground on the pin 5 on the car side of the connector and check for corrosion in the connector as mine had a little . The car side of the connector lifts straight up to unmount it to work with easier .
The pic is for the switch side of the connector
Note that it could be the battery transit isolation device to the BPM we'll look at later
Old 02-24-2018, 08:16 PM
Jagboi64's Avatar
Received 3,185 Likes on 2,101 Posts
I bought an XJR quite cheaply for the exact reason you mentioned: someone tried to jump start it and connected the cables backwards. In addition to fuses, both ECU and the AFM were also affected but only intermittently. Thus when they both went bad the car would randomly stall. Took me a while to find out why, but it was fixed when I replaced both parts.
To be honest with X300 values the way they are, it might be cheaper to buy another than fix everything.
Old 02-24-2018, 08:20 PM
shorty one's Avatar
Ok, thank you .
Figured out the random start issue.
Drove around for 15 minutes and all seems well.
We will see.
Old 02-25-2018, 04:28 AM
Mark Murphy's Avatar
So what was the cause ?
Old 02-25-2018, 07:40 AM
shorty one's Avatar
I will put my pride aside for others to know,,,,,,,,yes it can happen.
Well.............I hate to say it but........ for others.
Turn the ignition key all the way.
Ugh......
Turn it past where the steering wheel unlocks with pressure and the dash lights come on.
Turn it some more and the car starts,
  #28
Old 02-25-2018, 08:37 AM
Originally Posted by shorty one
Ugh......
So who hasn't been there
Old 02-25-2018, 10:28 AM
shorty one's Avatar
Yup............this is my first Jag and just got it.
I thought it had key ignition something different. Something, special.
chiro05
12-21-2014 04:20 PM
okstate734
07-19-2014 11:53 PM
jasont
XJ40 ( XJ81 )
04-09-2012 08:44 AM
tgds932001
09-26-2010 03:57 AM
jemetz49
XJ40 ( XJ81 )
03-01-2009 12:09 PM
Quick Reply: Battery hooked up backwards !!!
