Battery problem maybe?
Hi, so I have been driving the car all day, probably turned the engine on and off again a dozen times. Went to go out an hour ago in the car and nothing. All electrics are working but no start, not even turning over or even any clicks. I did notice both battery terminals where loose. I tightened both up but still no start. Any ideas please?
So put battery back on car after an overnight charge. Still not starting. All lights are out on dash except engine check light which I never had before. When I turn the key the airbag light comes on. The electrics are working except headlights and wipers. Interior lights not working either. All very strange. What could this possibly be??
in the meantime, check the engine ground points and then check the connectors on the engine and the engine control module to make sure they are clean and fully seated.
Also have a look at this
rob20087 (08-08-2013)
OkieTim
09-08-2015 04:48 PM
