Battery Vent Attachment
Old 07-27-2013, 10:00 PM
Oubadah's Avatar
Default Battery Vent Attachment
I recently discovered that my parents have no vent tube attached to the battery in their X300. It's been that way for years.
The battery (like every other battery I've seen) has vent sockets at both ends. I'm confused as to whether I need to plug up the end that will not have the tube attached - the battery didn't come with any such plugs. I've seen other batteries that do include a plastic plug to blank off one end, but then my X300 (which always had a vent tube attached) doesn't seem to have any plug on the other end.
I'm not sure whether some batteries have some kind of internal mechanism to blank off the unused vent, or whether you're supposed to supply a plug...
Any suggestions?
And here is a picture of one of the vent sockets:
Old 07-28-2013, 02:47 AM
GGG is offline
Received 16,865 Likes on 12,186 Posts
An OE Jaguar battery comes with BOTH vent sockets fitted with blanking plugs (circled in red on the RH side):
The 'L' shaped vent pipe adaptor is in a separate packet. When the battery is fitted, the LH blank plug is removed, discarded and replaced with the 'L' shaped vent pipe adaptor (arrowed in red on the LH side):
There MUST be a blank plug fitted to the RH side or fumes can vent directly into the luggage compartment.
thistle4celtic1 (03-12-2021)
Old 07-28-2013, 03:34 AM
Oubadah's Avatar
OK, so I'm guessing the blanks, adaptor and tube must have gone AWOL at purchase. I've found a spare blank on a dead battery, but does anyone know where to get those special adaptors on their own? The one this battery is socketed for is more than just an L shaped tube, it's got a fat body that fits into that oval socket (as pictured above) - my car already has one, and it seems to have some kind of filter in it.
EDIT: Here's a picture of the adaptor I'm looking for:
As you can see, it fits onto a plain socketed battery as well, but it's specifically designed for the type of socket pictured in my first post.
Old 07-28-2013, 04:02 AM
GGG is offline
I'm getting 'invalid attachment' showing for your picture link in post #3 ....
Old 07-28-2013, 04:28 AM
Oubadah's Avatar
I think it's the 'Moll' style adaptor my parents need.
Old 07-28-2013, 05:20 AM
GGG is offline
There's nothing listed in the Parts Catalogue other the vent tube. Neither the adaptor nor the blanking plug appear to be available separately from Jaguar.
Old 07-29-2013, 05:54 AM
OWRltd's Avatar
My car was also missing it's venting system. I found a replacement kit by Googleing bmw battery vent kit. Cheap and works.
trosty
26
12-18-2022 06:40 PM
danke
03-03-2016 10:57 AM
jaaag
09-11-2015 12:53 AM
stype40
09-09-2015 08:14 AM
DEklof
09-08-2015 05:28 PM
Quick Reply: Battery Vent Attachment
