best OBDII scanner for x300
That’s gonna cost you a lot more than $345 then. I don’t know about the Mini and the Mazda, but I’m order to access and clear ABS and Transmission codes on the Jaguar, it will need to be loaded with Jaguar specific software.
For the right amount, you can buy equipment that can also load BMW (for the Mini?) and Mazda protocols as well, but we’re probably talking about a four digit price.
Please keep us posted if you happen to find something that works!
Let me point you to this thread.
You can load bmw and Mazda on here as well but can not comment on these.
https://www.jaguarforums.com/forum/x...budget-249892/
jmstunts (12-20-2021)
Cafcpete (12-20-2021)
You should order that OBD2 reader so you can pull the transmission code. Not sure anyone can help you without knowing what the code, or problem is.
I can guarantee that the OBD2 reader will pay for itself, since it will pull the Jaguar specific ABS and Transmission codes, as well as the common P codes.
Something is clearly not right. You have a transmission light on (steady, not blinking) and an OBD2 reader that (allegedly) reads Jaguar specific transmission codes, but you come up empty?
How can we be sure that the reader does indeed read Jaguar specific transmission codes?
Have you ever been able to pull a transmission code previously? Any code? Is this the first time youre using this reader?
