Best Springs for the money?
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
So my 96 xj6 is making sounds like the original springs it has need to be changed. I cant really explain the sound but i figured since i put new shocks in it i might as well put new springs as well and with 93000 miles on the original springs i think its time for a change. My question is which springs are the best for these cars for the money?
![Icon Vp](https://www.jaguarforums.com/forum/images/smilies/icon_vp.gif)
Squeaky sounds from the (rear) springs are often caused by the upper spring insulator/cushion rubbing. Many recommend coating the upper surface that seats in the metal spring pan that bolts to the chassis with either a silicone grease (that's what I would use) or anti-seize (I would not use this as it contains oils that might damage the plastic spring insulator/cushion).
Springs themselves do not make (noticeable) sounds.
etaent (01-29-2012)
