Body Processor Unit
Body Processor Unit
I'm probably going to have to replace my body processor unit soon, I have found several used one's. If I find one that matches my year/make/model, will it have to be programmed or can it just plug and use? If it does have to be programmed, can a mechanic who specializes in European cars do this?
i have one if you need it
i have a bunch of spares for the 1996 vanden plas that I never put to use. I will be parting the car soon but in the meantime I do have the part you need.
if you like i can post on ebay for you. Contact me at jbeaufisk@yahoo.com if you like
Brad Livengood (01-18-2013)
Received 10,871 Likes
Don't take mine as the final word on this, but.....
I *think* you'll have to find a processor with the same part number and *suffix* or programming very well could be needed.
The vast majority of USA market cars were built/equipped the same way so your chances are good at getting an exact match.
I'm sure this suffix issue applied to engine ECUs. I'm not quite so sure it applies to body control modules.....but thought I throw it out there anyhow.
So, I got the part I ordered from Ebay. The part that came out of my car was LNA2500 suffix 007 - and the part I rec'd was the same. When the mechanic put the part in, it worked for approximately 1 min. then everything shut down and the same issues happened, car not starting, wiper doesn't work, headlights, marker lights, etc. Is the part bad, or is my security system shutting things down? I'm at my wits end with this issue.
FS[SouthEast]: S1 XKE OTS Left Tail-light
SCMike
09-22-2015 07:34 PM
