Bonnet Removal
Bonnet Removal
Hello everyone,
I have (finally) sourced a good used bonnet to replace my rather tatty one, half of it has been repainted in the past and has gone dull/flaked off back to primer. The jag is working at a wedding this Saturday so she must look her best! There will be my uncles X350 working too, so even more importance on her looking as good as possible, got to keep the X300 end up
Is it as simple as it looks to just unbolt the current and bolt on the new bonnet (and of course removing the gas struts)? I can see three beefy bolts, bolting onto the bonnet, on each hinge. Assuming the new bonnet is straight and unwarped I hope to have no alignment issues.
Thanks,
Tom.
Thanks,
Tom.
The bolts on the hinges have clearance holes. So, you snug bolts, then check alignment and move the bonnet in the clearance holes to align then finish tightning. You may have to fiddle a little. With luck, you will not not have to move the fenders (I guess you folks call them wings) to finish the alignment.
aholbro1
08-05-2021 05:02 AM
Dickie_L_J_O
09-13-2015 07:44 AM
