Brake Light Switch
So my car has no brake lights whatsoever. When the pedal is released after being pressed I get a blink from a single bulb on the light behind the rear window. The actual brake lights are inactive. I replaced the bulbs but no change. I've been reading that a failed switch will cause your car not to switch out of park though. Should I start with the switch or elsewhere? If I should start with the switch, does anyone know where I can buy it? Motorcarsltd has it at $77 and another $70 for the harness.
Received 10,871 Likes
The rear window brake lamp working suggests that the switch is OK.
The regular brake lamps are wired through a solid state "rear lamp control module". I suspect a problem there....but I've never had to do any repairs in this area so I'm talkin' outta my hat.
Others will chime in.
Guest
Posts: n/a
I have no brake lights and can't shift from park. Removed brake switch. It has two switches, one normally open, one normally closed (is that correct?). Both work electrically. Color code does not match wiring diagram. It has a purple and white/blue wires going to one switch, and a purple/blue and white/orange wires to the other? According to the wiring dia, they should be one purple, one blue? Part number on switch assembly is DBC 10800 (that no. matches the wiring dia.). Anyone know which switch is the brake switch? Should it be normally open or closed? Or are both supposed to be the same? I think the other switch controls the speed control?
You probably don't need the harness Motorcars is talking about. That is needed to use the switch on an XJ40, they discontinued the DBC 10800 switch when the X300 came out in favor of the LNA 6420BA. The X300 sw had no flylead like the XJ40 switch. The harness makes up for the short harness that can't reach the X300 switch.
You might check the plug in diode the is beside the battery, it is in the circuit to the High Mount Stoplight relay. Just a thought.
EDIT: Jees, after further pondering I realized I wasn't quite right above. The early X300's also had the XJ40 style switch and were in need of the additional harness. If the switch currently in the car has a connector on it, no harness will be necessary. If it has a lead about 4-5 inches long, it will need it.
My apologies for the faulty gray matter!
Cheers,
Cheers,
ok so after looking in my luggage compartment fuse box I've found that I have a Combined Lamp Control Module. I took it out and started my car and turned on the lights to see what it controls and all my exterior lights did not work except for my headlights but I didn't try my hi-beams. I cleaned the connections with some electrical spray and put it back in to find no difference. Would this imply that my switch would be the issue since I don't have a rear lamp control module?
KarimPA
09-12-2015 08:15 AM
