Brake pads
Not hard at all; just make sure you have the right allen key (7mm IIRC?) and something suitable for retracting the piston - and be sure that your discs aren't in need of replacement too. Oh, and keep your fingers crossed that the piston does indeed retract nicely - otherwise you'll be rebuilding/replacing the calliper. I don't know how common that is (it did happen to me though!), but it's worth being prepared for...
awil (03-20-2013)
Rear bolts on mine were safety-wired. No big deal, but added $20 or so pair of safety wire pliers and roll of wire from ATS that wasn't previously in my "brake job tools" kit! I do have a nice tool for retracting the pistons....but since handbrake on these is a set of drum brakes, I believe you can use a c-clamp like on the front. I crack the bleed screw open and push the old fluid out as I compress the piston rather than push it back up into the reservoir. Either way works...my way just remember to top-up reservoir between wheels, opposite way, be prepared to deal with the possibility of overflowing it.
I do have some pictures...but you'll have to scroll down past all the a/c condenser shots...the brake pictures are "bracketed" by pics of the Andy-Bracket - when you see it, start looking for brakes..and when you see it again, you've reached the end of the brake pics....
VDP Mechanicals Photos by holbrz1 | Photobucket
awil (03-20-2013)
FS[Western US]: Jaguar X308 MISC Parts
perezal
12-29-2015 08:48 PM
1964Daimler
09-09-2015 11:28 AM
