broken door handle in and out
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
can someone help, i bought a 97 xj6 that has it's outside drivers door handle broken off and inside drivers door cable snapped, which makes it impossible to open that door, i can't take the door panel off without opening the door first? maybe someone knows a trick to open the door so i can repair, thanks
are you positive the door panel wont come off without being able to open it, it may take a little force. Also depending on where the cable inside broke perhaps you could grab it with some pliers and pull it. Maybe you could get just the top part off and even that would be enough to get it open with pliers.
I thought about this also, but the three screws behind the trim have to be removed and then there's the little screw behind the lip of the rubber air thingy that is sandwiched between the door and the side of the dash. (vents air through to the door/window to demist) The door would absolutely have to be open to access this. Not sure either if the trim will slide forward enough to disengage off the clips it fits onto. Is there any way of maybe tripping the lock open from inside, using a flexible flat blade between the door and the pillar? It's a fairly straightforward approach?
thanks for everyone's replies but i was able to open the door from the outside by sliding a small screwdriver under what was left of the plastic door handle and lift it up while a friend pushed the door open from the inside![Icon Woot](https://www.jaguarforums.com/forum/images/smilies/icon_woot.gif)
the door assy is a poor design acct. all the lifting pressure is concentrated on only the right side of the handle, the left side does no actual pushing down on the latch rod, also the cable frays on the inside handle acct. the inside mech. is very sticky/ or hangs up/ defective and repeated pulling will eventually lead to cable failure. must order all new driver latch assy. now. but problem solved!!
Andrew Fanshawe
09-14-2015 07:40 PM
1964Daimler
09-09-2015 11:28 AM
