Buying a '96 XJ6
Hi MTZ
A couple of things.........
Front and rear bumpers (fenders) can fall off due to corrosion of the two brackets holding them on. These are NOT expensive, but unfortunately are made of Mazak, ( I think called ZAMAK in the US) so they just dissolve away ! If bumpers feel loose, fix them soon before they fall off while you're going along, you can get the brackets easily.
Thumpy noises from rear end is usually the rear suspension A bracket bushes, again, not expensive.
rusty37
04-05-2020 07:40 PM
