A/C backlight and radio antenna questions
Old 01-12-2012 | 08:33 PM
TopHatChef's Avatar
Default A/C backlight and radio antenna questions
Okay, two little q's:
The backlight on the A/C temperature screen went out, how do I replace it? Can I?
My radio antenna recently stopped going up and down. I think it's just the antenna by the sounds of it when it was breaking (sounded like the plastic bit inside broke), but I don't hear the motor. Where's the best place to buy a replacement?
Old 01-12-2012 | 11:10 PM
Doug's Avatar
If you remove the radio/climate control/clock stack you'll see that the climate control head has a plastic cover on the back. Remove the cover and you'll see the replaceable twist-lock bulbs.
Replacement bulbs are tricky. I bought umpteen different ones on-line for $1 each but none matched the color/instensity of true Jaguar bulbs....which are "stupid expensive" at $6-$7 each.
The antenna's nylon drive cable probably broke. I got a replacement on Ebay as I recall...less than $20 I think. It comeas as a mast-cable assembly. Sometimes the new cable can simply be fed into the motor, letting the take-up wheel pull the new cable in.
In my case there were broken bits inside...so I had to open up the motor. No big deal.
TopHatChef (01-14-2012)
Old 01-14-2012 | 12:46 PM
TopHatChef's Avatar
Thanks loads Doug. I knew you'd know what I'd need to do. I'll probably just go get the bulbs at the dealer. I recently moved, and the local dealer is right next to a mall I like and haven't gotten a chance to visit them. If I'm going to go through the PITA motions of removing the climate control, I'm only going to do it once.
Old 01-14-2012 | 12:56 PM
TopHatChef's Avatar
I just went on eBay looking for the antenna. Can anyone recommend a good seller to look for? I can't remember the guy I've used before for Jag parts, and can't seem to find it in my history because it's been so long since something's gone wrong.
Old 01-14-2012 | 01:40 PM
Doug's Avatar
This is the same antenna and supplier I used
URO Power Antenna Mast for Jaguar LNA4134AA | eBay
Looks like the price went up a bit....or perhaps I wasn't remembering correctly
Old 01-15-2012 | 06:12 PM
gbmtkj's Avatar
I recently bought and installed this one on ebay:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
It claims to be stainless instead of aluminum, which it implies some others are (?).
$14.95 + $5 shipping.
It arrived quickly, and installed easily. Came with removal and installation instructions, although I also had some from the forum.
mbergen
10-23-2019 11:26 PM
Dz1rfj
07-17-2018 11:29 AM
Dz1rfj
09-16-2015 04:44 PM
Saturbo
09-08-2015 08:35 PM
TexasCat
09-08-2015 05:36 AM
Quick Reply: A/C backlight and radio antenna questions
