A/C compressor not running because belt is too loose.
Old 06-25-2013 | 12:40 PM
TopHatChef's Avatar
Default A/C compressor not running because belt is too loose.
My a/c belt keeps going loose, causing the compressor not to run, resulting in my a/c system blowing warm air. I know it's because the tensioner isn't keeping the belt tight enough because the bolt used to adjust it keeps getting lose, so I have to tighten it. I plan on taking the belt, bolt, and pulley off, and cleaning the whole area well to see what's up. Has anyone encountered or done this before? My only experience in this area of the car was when I replaced the belt about 2.5 years and 30k miles ago. I am quite confident the belt is still good.
Old 06-25-2013 | 01:21 PM
Roger95's Avatar
I just did mine this weekend. My car is a '96 VDP w/122K miles. Get a new belt first of all. Climb under the front of the car, look up at the adjuster; there are two hex head cap screews with 10mm hex heads, remove the screws the adjsuter will just drop in your hand. The tensioner bearing is held by a 10mm hex head screw, disassemble (5 parts), clean, lube reassemble, adjust belt. Pretty easy really. I'd use a new tensioner bearing as well...
Good luck
TopHatChef (06-26-2013)
Old 06-25-2013 | 01:26 PM
mgb4tim's Avatar
Is the compressor clutch engaging?
Old 06-26-2013 | 12:43 PM
TopHatChef's Avatar
Thanks Roger. I'll probably be taking care of that tomorrow. Hopefully I can get a new bearing on the cheap, otherwise it may have to wait a little.
Tim, I am quite confident the compressor clutch is engaging, but since this is my first A/C problem in this area, I don't have much knowledge of the compressor. I learn about things on my car as they go wrong for the most part, although I do try to keep prepared.
Old 06-26-2013 | 02:44 PM
mikesmith2's Avatar
If you look at the front of the compressor pulley when the A/C is engaged the centre should turn as well.
If it doesn't then the problem lies elsewhere
Old 06-27-2013 | 05:35 PM
TopHatChef's Avatar
Yeah, the compressor clutch isn't always engaging. I did clean off the tensioner and all because it had been loose. The compressor wasn't on when just idling, but kicked on after I revved the engine to just under 2000 rpm with the a/c off, and then turned it on. Now it seems that my problem lies in my compressor not always engaging.
Old 06-28-2013 | 01:09 AM
mikesmith2's Avatar
That could be down to low gas.
Have you had it checked?
Dicque
09-19-2015 01:53 PM
tberg
09-07-2015 08:32 AM
Corycarlo
09-05-2015 12:41 PM
AL NZ
09-04-2015 09:39 PM
d a
09-03-2015 03:34 AM
Quick Reply: A/C compressor not running because belt is too loose.
