A/C drive belt
Old 03-26-2018, 02:41 PM
xjfourty's Avatar
Default A/C drive belt
my A/C drive belt is cracked, need to replace it.
Is it a hard DIY work ?
is it feasible by myself ?
is there any hint or guide to follow ?
thanks
Old 03-26-2018, 03:02 PM
Ric in RVA's Avatar
About as simple as it gets.
Jack up and support right front corner.
Feel tension on belt now. Note in mind that this is minimum you want on re install. (or you can get a cricket tensioner gauge....the small one)
Loosen nut behind tensioner pulley. Just enough that the pulley can slide up or down to adjust tension.
Using bolt running vertically to tensioner allow tension to ease.
Remove belt.
Check tensioner pulley for free running. Or just buy new one. See threads for a lincoln based all metal version.
Slide belt on and hand tighten pulley bolt. Tighten the vertical part of the tensioner to approximate what you had to begin with and add a small amount more since belt will stretch slightly. (or use your fancy tensioner gauge.)
Plan on it slipping once it gets bedded in and retension when it does.
Old 03-26-2018, 04:51 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
Error .
Old 03-26-2018, 05:00 PM
The tensioner long bolt with the squire head on mine was frozen with rust . I removed the belt and took the whole tensioner assembly to the bench and heated up the square running nut with some heat and penetrating oil and wire brush to break it free so it will adjust . Try to save the square points as you can pound a socket on backwards with the 4 point socket out to receive a extension for future in service ease , but not until after freeing it up first with vise grips.
You have to loosen up ( not all the way out ) bolt # 4 so the pulley will adjust as the first step .
East to do but costly at a shop if frozen .
Old 03-27-2018, 07:21 AM
aholbro1's Avatar
Received 1,642 Likes on 1,068 Posts
If I recall, "tightening" the long vertical bolt (turning it to the right) eases drive belt tension and vice-versa. Not intuitive.
As Ric said, make sure you loosen the pulley bolt, or you'll never loosen the drive belt tension.
Here's pics and a how-to:
https://www.jaguarforums.com/forum/x...lt-how-102387/
Teck4Jag
09-22-2017 02:26 PM
Ragn0r
04-18-2016 05:49 AM
XKR2000
09-05-2014 07:57 PM
Bacardi 151
06-01-2012 03:16 PM
2000blackxkr
09-13-2009 10:28 PM
Quick Reply: A/C drive belt
