A/C not blowing cold at low speeds
So, the A/C on my 97 Xj6 does blow cool air, but not at idle or low speeds. The air will only blow cold when I'm on the road traveling at around 30+ mph.
Now, I've been advised that there could be a clog of sorts in an intake? The air does blow cold, so I wouldn't think it to be the coolant. I'd love to know what you guys would think it could be. It was nearly 90F out today and Sunny.
Couple of questions bouncing around my head.
Are the electric fans actually BOTH running on LOW when the A/C is ON. This would explain the colder air when moving, coz you got air flow across the condensor to do what it should, and ZERO at idle if the fans are not BOTH running, due to no air flow. These fans are well documented as failing eventually, and/or the relay pack (inside the LHF wheel well) is playing up, again, well documented.
Is the belt TIGHT, and more importantly, the idler pulley still OK, as it is plastic and only lasts so long. This is NOT high on the brain bounce, just mentioning coz I can.
The charge level of "stuff" may be low, and the higher revs actually pumps a tad more to give that cool feeling. Again, not real high on my list.
OkieTim
09-08-2015 04:48 PM
